Hey Circuit Team,
Sorry if this isn't in the right category you are welcome to change it.
What I'm aiming to achieve here is to construct a circuit/layout capable of switching over to a different voltage source when detected from an external source.
Let's consider an example:
I currently have a 5V source supplying power, which must initially undergo a handshake process with my phone to detect a signal. Once the signal is detected, the Dashboard screen will display a Navigation Map. However, the 5V 1Amp output, used to charge the latest phones, isn't sufficient.
Therefore, I'm aiming to supply 12V power along the same line as the 5V, but I want this 5V power to be cut off once 12V is detected automatically. Essentially, when the 12V power source is manually activated, I want the 5V line to deactivate, allowing the 12V power to take over.
I've managed to achieve this manually, but now I'm looking to automate the process.
My question is, would using one or two relays to make this process, or is the solution a bit more complex than just utilizing relays?
