So you don't care if the bass frequencies also go to the rest of the speakers?I want a Filter which only lets bass Frequency pass, no Crossover.
That likely will lead to a peak in the mid-bass frequencies.
But I already did.dont ask why
Okay, but if your main speakers don't have a good low frequency response, you may end up increasing only the higher bass frequencies.In general just to have bass louder
Just a note, you should also check the phase shifts when dealing with audio or you may not like the sound quality.Hey guys,
I bought one of those mono amplifier boards for subwoofers etc. Since it only has 1 input channel ( and ground ) and no Bandpass filter ( which i need, because i wanna use it as a subwoofer amplifier ) I tried developing a Circuit which combines those 2 circuits. I did that by using
http://falstad.com/mathphysics.html
the analog Filter and the analog Circuit simulator applet. Both circuits worked ( IN THEORY ) just as i wanted them to. View attachment 191225View attachment 191227
( The 2 signal sources are the Left and Right channel from my Aux cable/3.5mm Phone Jack )
Im quite sure the summing amplifier should work just fine as i planned it ( correct me if not ).
But finally after recieving the PCB and the Components and testing it all, it didnt work. After trying to only use the Mono sum part, i heared noise and very light music ( my input signal ) when connecting a test speaker ( I dont have measurement equipment accurate enough for this )...
Is the reason just bad contacts or why doesnt it work?
Thank you in advance
The ear is not sensitive to phase shift.you should also check the phase shifts when dealing with audio or you may not like the sound quality.
Maybe your ear isnt, but everybody else's isThe ear is not sensitive to phase shift.
But that's not an effect of the ear being sensitive to phase.Two striking examples are the guitar phase shifter sound effects pedal and with stereo channel audio outputs when they mix so the listener hears the sum of the two channels.
It's the adding or cancelling of the two wavefronts in the air as their relative phases are shifting which changes the sound intensity..
That can be measured with a sound meter.
But your point is valid.
The relative phase of the sound coming from two or more speakers is definitely of concern.
In the case of a subwoofer, the placement in the room also affects the phase of the sound relative to that from the other speakers.
Hi,I think i know how the thing with Phase works... Two waveforms add up as soon as they hit each other.. If they both are 0 degrees phaseshifted, then their Amplitude adds up. If they are 180 degrees relative to each other Phase shifted, they cancel each other out. But u cant head a Phase shift. The only thing u might hear is the change when playing the note, and WHILE the note is playing, you activate the Phase shift. But if u Play those 2 Notes seperately, you shouldnt hear anything, since it is same shape, same Amplitude and same frequency. The difference in Phase just acts like if you were standing a bit further away / a bit closer to the speaker.
| Thread starter | Similar threads | Forum | Replies | Date |
Inverting summing amplifier help please? | Digital Design | 28 | |
Inverting summing amplifier help please? | General Electronics Chat | 16 | |
Summing Amplifier Channel Isolation Problem | Analog & Mixed-Signal Design | 11 | |
| E | Summing amplifier | Homework Help | 11 | |
Ripples in square wave output of LM7171 high speed OpAmp. | Digital Design | 19 |
