I am repairing a newer model NewAir dual zone cooler. It has a newer PCB form factor, but the same basic circuit as the FX101, FX102 boards. This cooler uses 2 identical PCBs and TECs. the PCBs are labeled MP-012 PCB120102K3. The only difference to the FX102 is that C10 is 1000uf 16V rather than 2200uf. Again, as in the other PCBs, C8 is the main cause of failure, as it provides the filtering to power the start-up control. Scanning thru the updated Caps.pdf file, you can see that many other caps are bad or marginal. But I don't think it is necessary to replace the main HVDC filter caps. These seem not to dry out as fast as the other caps and are much more expensive.
C12/C15 stable ESR could be because there is much more electrolyte volume per diameter. Also note that all of these PCBs use caps made by Aishi. Maybe a brand to be avoided.
I added measured data from the new caps (Wurth, Nichicon, Lelon) to the cap.pdf tables. Note that their ESR is inline with the "good ESR less than" column. So replace all but C12/C15. I will post some photos and data after the repair of all 3 PCBs.
