Yeah, but that has only just become an a-level.
It's the transferrable skills. You find if someone can speak a second language, they can pick up others easier. So if someone learns German, they can pick up French, Italian, whatever easier than someone who hasn't.
Well, how close are German and a programming language?
They both have semantics, they both have a grammar, they both have a syntax and a morphology.
Just because you are using it to communicate with a machine, doesn't mean it isn't another language.
Sure, they have a very different way of making a point. The use of words/punctuation/order of the language is very different.
By then so is every language.
The point I'm making is that this is about transferrable skills. If I have managed to learn a second language, then that shows I should be able to pick up another easily, wether it is French and Italian, or ASM and C++.
How often does one just add two number together? Not often. Does that make that skill useless? No. The skills you learnt from adding two numbers allowed you to add bigger numbers, add algebra, learn multiplication, etc, etc.
