I'm currently refurbishing an old Studer 169 mixer console from the 70s. I'm pretty much recapping it as it would not turn on when I tried to power it on recently.
I'm trying to get the power supply to work first. I recapped it and the AC readings are good but the DC readings at the end are too high, I'm reading +48v, +26v, 0v, -26v instead of +48v, +15v, 0v, -15v. This causes the safety circuit to trip the relay and turn off to avoid damaging the console. To get the DC readings I'm bypassing the safety circuit as indicated in the documentation to debug a problem.
I have checked all diodes with a multimeter and they seem fine (diode test on the circuit). I can feel heat in the components at the bottom left of the board (resistors area) but not much elsewhere, when I send current for ~10 sec (then I stop).
I've attached the documentation with schematics and pcb layout for reference. And also a picture of my power supply recapped.
Any tips is on how I could find the issue is welcome!
Thank you,
Octave
Thank you,
Octave
