Strange Regulator/MOSFET behaviour
sirch2
Joined Jan 21, 2013
1,079
Quick summary... I am running a MOSFET as a switch driven by an Arduino. The MOSFET switches a voltage regulator which powers a bridge circuit and instrumentation amp. It all seems to run okay, the MOSFET switches, the regulator outputs 5v the bridge circuit turns on but the bridge/instrumentation amp is always at about 4.7V. If I power the bridge circuit from a power supply at 5V it works fine and I can tweak a pot to get the bridge to a set point but not if I power it from the MOSFET/regulator.
The MOSFET REG -
The bridge circuit
Any thoughts? One thing I did notice is that if I connect the bridge ground to the Arduino ground rather than pin 2 of the LM78L05 the bridge is at about 2.7V but from pin 2 of the LM78L05 it is at 5V
ronsimpson
Joined Oct 7, 2019
4,888
What is the voltage on 78L05-1?
What do you want on "5VJOut?
Q1-1 is that ground?
What does R1 connect to?
There are so many questions.
BobTPH
Joined Jun 5, 2013
11,678
You MOSFET is wired entirely wrong.
The gate should be controlled by the Arduino, you have it grounded.
But then, an N-channel is the wrong type, anyway. You need p-type controlling the input to the regulator.
sirch2
Joined Jan 21, 2013
1,079
Hmm, good spot about the MOSFET, the diagram is wrong, not sure how I managed that the Gate goes to the Arduino the Source to ground. I am running the Arduino at 3v3 but the bridge circuit needs 5V so my understanding is that I can't use a P-Channel because the gate would not go high enough to turn on? I'll double check the board to make sure I have the MOSFET correct though ...
For info JOut is the power to the bridge circuit, basically the Output of the LM78L05 is connected to X1 of the bridge circuit. Thes are built as two separate units and I don't have a combined diagram. The rest of the first circuit is really just a bunch of sockets for various modules so wouldn't add much
sirch2
Joined Jan 21, 2013
1,079
So this is the actual MOSFET arrangement
VBattery is about 8V from two 3.7V Lithium batteries, JOut is 5V when the MOSFET is on.
As I said it seems to work as expected, the MOSFET turns the LM78L05 on and off, its just leading to odd behaviour from the bridge circuit. The bridge circuit works fine when powered from a power supply
BobTPH
Joined Jun 5, 2013
11,678
You need another transistor, n-MOSFET or NPN BJT to switch the gate of a p-channel. I try to avoid switching ground on anything involving electronics and signals. It is fine for a light or a motor or relay.
dl324
Joined Mar 30, 2015
18,521
You just need to use an N type device to drive the P channel MOSFET.
Why do you have so much whitespace, extraneous connection dots, and the awkward flow?
R1 isn't needed.
ElectricSpidey
Joined Dec 2, 2017
3,370
I can't possibly see how that configuration can possibly turn a 3 terminal regulator on and off.
If you let the common connection(ground) float the output will go to the supply minus the dropout.
ronsimpson
Joined Oct 7, 2019
4,888
Some one tell me how this works.
I see that it works when the MOSFET is on.
When ground is cut open, 78L05 pin 2 can float up or be pulled down to -1V before it hangs up on the diode in the MOSFET.
ElectricSpidey
Joined Dec 2, 2017
3,370
I think the correct way would be to set up a MOSFET as a switch on the output of the regulator and before the output cap if it's a big one.
And leave a small cap right at the regulator to prevent oscillations.
Or the switch can be before the regulator to save a little power.
ElectricSpidey
Joined Dec 2, 2017
3,370
I just ran an LTSpice sim using the supplied LT1083-5 regulator with a 10 ohm resistor and 8 volt supply.
The output was just as expected 5 volts and 500mA.
Then I opened the ground pin and the regulator did just what I expected.
The voltage went up to 7 and the current went to 700mA. (aprox)
ElectricSpidey
Joined Dec 2, 2017
3,370
I know that's not the same design but I couldn't find a 78XX model and I assumed that it would expose any inherent reason that a 3 terminal regulator wouldn't behave the same.
The only reason I know how the 78XX regulators behave when you pull the ground pin is I have seen it on the bench, long before I used any simulators.
I will have a look see if I can find a 78XX series model and do the simulation again.
Ian0
Joined Aug 7, 2020
13,317
Any sort of 5V regulator will be trying to maintain 5V between gnd and output terminals. If the ground terminal is not connected to ground, the only way it can go is up, due to the quiescent current.
