STM32F407VG Traffic control system
Hamnah-Malik
Joined Nov 25, 2024
7
I am trying to make a three way traffic controlling system i have already configured and made my block diagram i am using ultra sonic sensors to control the traffic lights so that if the sensor detects more traffic the time for the light to stay green increases i am also using a sensor for the pedestrians but my code isnt working correctly the sensors arent taking readings correctly and the lights arent function as i want i am attaching my code below please help me pinpoint the issue
Mod: please use Code quotes
C-like:
#include "stm32f4xx.h"
// Delay using SysTick
void delay_us(int us) {
    SysTick->LOAD = 16 - 1;  // 1 us tick at 16 MHz
    SysTick->VAL = 0;
    SysTick->CTRL = 5;       // ENABLE + CLKSOURCE
    for (int i = 0; i < us; i++) {
        while (!(SysTick->CTRL & (1 << 16)));
    SysTick->CTRL = 0;
void delay_ms(int ms) {
    for (int i = 0; i < ms; i++) {
        delay_us(1000);
void GPIO_Init(void) {
    // Enable clocks for GPIOA, GPIOB, and GPIOE
    RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN | RCC_AHB1ENR_GPIOBEN | RCC_AHB1ENR_GPIOEEN;
    // GPIOA0–A8 as outputs (traffic lights)
    GPIOA->MODER &= ~(0x3FFFF);
    GPIOA->MODER |=  (0x15555);  // 01 = output
    GPIOA->OTYPER &= ~(0x1FF);   // Push-pull
    GPIOA->OSPEEDR |=  (0x3FFFF);
    GPIOA->PUPDR   &= ~(0x3FFFF);
    // PA9 = TRIG A (output), PA10 = ECHO A (input, default)
    GPIOA->MODER &= ~(3 << (9 * 2));
    GPIOA->MODER |=  (1 << (9 * 2)); // PA9 output
    // PB10 (TRIG B), PB12 (TRIG C), PB5 (TRIG Pedestrian) -> output
    GPIOB->MODER &= ~((3 << (10 * 2)) | (3 << (12 * 2)) | (3 << (5 * 2)));
    GPIOB->MODER |=  ((1 << (10 * 2)) | (1 << (12 * 2)) | (1 << (5 * 2)));
    // PB11 (ECHO B), PB13 (ECHO C), PB4 (ECHO Pedestrian) -> input (default)
    // PB8, PB9: Pedestrian LEDs -> output
    GPIOB->MODER &= ~((3 << (8 * 2)) | (3 << (9 * 2)));
    GPIOB->MODER |=  ((1 << (8 * 2)) | (1 << (9 * 2)));
    GPIOB->OTYPER &= ~((1 << 5) | (1 << 8) | (1 << 9) | (1 << 10) | (1 << 12));
    GPIOB->OSPEEDR |= ((3 << (5 * 2)) | (3 << (8 * 2)) | (3 << (9 * 2)) |
                       (3 << (10 * 2)) | (3 << (12 * 2)));
    GPIOB->PUPDR &= ~((3 << (4 * 2)) | (3 << (5 * 2)) |
    // Enable clock for GPIOE
    RCC->AHB1ENR |= RCC_AHB1ENR_GPIOEEN;
    // Set PE7 as output (Debug LED)
    GPIOE->MODER &= ~(3 << (7 * 2));  // Clear mode
    GPIOE->MODER |= (1 << (7 * 2));   // Set as output
    GPIOE->OTYPER &= ~(1 << 7);       // Push-pull
    GPIOE->OSPEEDR |= (3 << (7 * 2)); // High speed
    GPIOE->PUPDR &= ~(3 << (7 * 2));  // No pull-up, no pull-down
// Ultrasonic distance reading in cm
uint32_t read_distance_cm(GPIO_TypeDef* TRIG_PORT, int trig_pin, GPIO_TypeDef* ECHO_PORT, int echo_pin) {
    TRIG_PORT->ODR &= ~(1 << trig_pin);
    delay_us(2);
    TRIG_PORT->ODR |= (1 << trig_pin);
    delay_us(10);
    int timeout = 30000;
    while (!(ECHO_PORT->IDR & (1 << echo_pin)) && timeout--);
    int count = 0;
    timeout = 30000;
    while ((ECHO_PORT->IDR & (1 << echo_pin)) && timeout--) {
        delay_us(1);
        count++;
    return count / 58;
uint32_t get_stable_distance(GPIO_TypeDef* TRIG_PORT, int trig_pin, GPIO_TypeDef* ECHO_PORT, int echo_pin) {
    int readings = 5;
    int valid = 0;
    uint32_t total = 0;
    for (int i = 0; i < readings; i++) {
        uint32_t dist = read_distance_cm(TRIG_PORT, trig_pin, ECHO_PORT, echo_pin);
        if (dist > 0) {  // Accept all non-zero readings
            total += dist;
            valid++;
        delay_ms(20);
    if (valid >= 3)  // Use if at least 3 readings were successful
        return total / valid;
    else
        return 999;  // Signal: no object reliably detected
void set_light(int base_pin, int red, int yellow, int green) {
    GPIOA->ODR &= ~(0x7 << base_pin);
    if (red)    GPIOA->ODR |= (1 << base_pin);
    if (yellow) GPIOA->ODR |= (1 << (base_pin + 1));
    if (green)  GPIOA->ODR |= (1 << (base_pin + 2));
void turn_red_all() {
    set_light(0, 1, 0, 0);  // A
    set_light(3, 1, 0, 0);  // B
    set_light(6, 1, 0, 0);  // C
int get_green_time(uint32_t dist) {
    int green_time = 5000;
    if (dist < 20) green_time = 10000;
    if (dist < 10) green_time = 15000;
    return green_time;
void run_traffic_cycle(int road) {
    int base_pins[3] = {0, 3, 6};
    int base = base_pins[road];
    turn_red_all();
    if (road == 0)
        green_time = get_green_time(get_stable_distance(GPIOA, 9, GPIOA, 10));
    else if (road == 1)
        green_time = get_green_time(get_stable_distance(GPIOB, 10, GPIOB, 11));
    else if (road == 2)
        green_time = get_green_time(get_stable_distance(GPIOB, 12, GPIOB, 13));
    set_light(base, 0, 0, 1); delay_ms(green_time);
    set_light(base, 0, 1, 0); delay_ms(2000);
    set_light(base, 1, 0, 0);
void check_pedestrian_and_run() {
    uint32_t pdist = get_stable_distance(GPIOB, 5, GPIOB, 4);  // Get distance from pedestrian sensor
    // Debugging: Check the distance reading
    if (pdist < 40) {  // If a pedestrian is detected within 40 cm
        // Turn off the red LED and turn on the green LED for pedestrian
        GPIOB->ODR &= ~(1 << 8);  // Red OFF
        GPIOB->ODR |= (1 << 9);   // Green ON
        // Debugging: Turn on the debug LED (PE7) to indicate pedestrian detected
        GPIOE->ODR |= (1 << 7);   // Debug LED ON
        delay_ms(5000);           // Pedestrian green LED stays on for 5 seconds
        // After the pedestrian has crossed, turn off the green LED
        GPIOB->ODR &= ~(1 << 9);  // Green OFF
        GPIOB->ODR |= (1 << 8);   // Red ON
        // Debugging: Turn off the debug LED (PE7) after pedestrian is done
        GPIOE->ODR &= ~(1 << 7);  // Debug LED OFF
    } else {
        // No pedestrian detected, ensure the green LED is off
int main(void) {
    GPIO_Init();
    GPIOB->ODR |= (1 << 8);  // Pedestrian red initially ON
    while (1) {
        run_traffic_cycle(0);
        check_pedestrian_and_run();
        run_traffic_cycle(1);
        run_traffic_cycle(2);
atferrari
Joined Jan 6, 2004
5,030
Is the increasing of time for one of the streets (assisted by sensors) required for the design? The beauty (in grid like distribution of streets) resides in the regular opening/closing of green lights in the whole area.
Hamnah-Malik
Joined Nov 25, 2024
7
yes we were asked to make it like that
