stepper motor overheating.
lawofsine144
Joined Jun 9, 2025
25
Update:
I bought a new L298N module to drive my stepper motor and after running(only around 10rpm) for 10 seconds, 12V Power, i smelled the magic smoke out of the L298N IC and the IC is burning hot .:D
I think i'll give up on this stepper motor and look for spare dc motors instead.... BTW i am making an electric turntable for my wife .
haha
BobTPH
Joined Jun 5, 2013
11,661
Update:
haha
You cannot simply apply 12V to the motor. It hits max current at 2.8V. It has to be PWM, preferably with current feedback.
28,411
I suggested the solution back in post #14.
The unfortunate reality is that the driver you have is not able to be set to the low current that the motor should have.
"Wishing it did have that ability will not make it so!! No matter how hard you wish!!
If the 24 volts is from an external power supply, then put the resistor in series with the 24 volt positive.
If the 24 volts is from a supply in the driver, put a resistor in series with each of the two motor windings.
MAX can wish for the required setting to be available on the driver, but that will not cause it to be available.
lawofsine144
Joined Jun 9, 2025
25
I am using an arduino to move the stepper, and i am using a stepper library which is PWM, i am confused because using the DQ860HA @24V will make the stepper motor overheat but if i use the L298N module at @12V , the L298N IC overheats.
Both drivers are PWM.
lawofsine144
Joined Jun 9, 2025
25
yes i think putting a series resistor works but i think i'll use a DC motor for now.
Thanks for the feedback guys, i will be closing the thread
BobTPH
Joined Jun 5, 2013
11,661
Try running it at 3V. That should be sufficient to run the motor at 10 RPM. Higher voltages are needed only at high speeds.
MaxHeadRoom
Joined Jul 18, 2013
30,842
Update:
haha
It can be done quite easily with the L298, but in conjunction with a L297 translator IC This way you can set the correct motor current for NEMA17 size, and also juse use simple single pulse control for RPM.
See L297 spec sheet.
You will not need PWM, just a pulse.
BTW, the popular board sold with the L2898 mounted, does not have the output for the current monitoring resistors that are need when using the L297, it can be modified with care however.
If you need the circuit. let me know.
