Stepper Motor Driver
Joined Jul 22, 2021
Dear all,
New to this forum, looking forward to any suggestions the community can provide.
I have a Unipolar Stepper Motor:
-Type: 6 wire 4 phases + 2 common signals (1 common signal for phase 1 and 3 and another one for phase 2 and 4).
-Input voltage: 25V (Max transient voltage 60V) Command is made with constant current provided.
-Step: The stepper motor is driven in “half step” mode (i.e: phase1, phase 1 + phase 2, phase 2, phase 2 + phase 3, phase 3, phase 3+phase 4, phase 4, phase 4+phase 1, loop) (360/0.5= 720 step per 360° revolution)
Each half step make the rotor rotate of a 0.25° angle.
-Current draw: 500mA (total command current) => one phase activated : 500mA, two phases activated: 250mA per phase.
Q: Looking for an off the shelf driver for this type of stepper motor, please advise?
Thanks in advance.
747
shortbus
Joined Sep 30, 2009
10,050
Don't quite understand why your calling a 6 wire stepper a unipolar but that's up to you. What your looking for though is any of the stepper drivers that are based on a TB6600 chip. They are the easiest to work with and in my experience the most reliable. Just one link to what I mean, they are available many places for less money(Ebay), just look for the TB6600 name when looking. https://www.robotshop.com/en/tb6600-stepper-motor-driver.html
shortbus
Joined Sep 30, 2009
10,050
But a 6 wire motor to my understanding can be used as both a bipolar or unipolar, depending on if you use or don't use the winding center tap.
