Stepper control
grangrad05
Joined Aug 14, 2013
11
I have a stepper motor control box and need to know how the wiring diagram is configured from the driver boards to the electronic panel then onto the P C .Also what voltages are required
BR-549
Joined Sep 22, 2013
4,931
It will depend on how the driver board, the electronic panel, and the PC is wired.
That means you need to find the schematics/data sheets of the driver boards, the electronic panel, and the PC.
It's a little more than just matching the wires up. Voltage and current/power need to be matched also.
You will also need the motor data sheet.
