Stepdown Transformer
38,945
Whilst you should dump some power with a resistor in series with each string, switching the strings on and off quickly is the most efficient way to control brightness.
Unless you use an inductor in series with the LEDs to control the current, PWM is no more efficient than linear current control.
LowQCab
Joined Nov 6, 2012
5,102
The 1074 Switcher that I suggested has an "Enable" Input that
can be used for relatively low-Frequency PWM Dimming. ( ~200hz )
