Is that the input current or the output current? If the input is 48 V @ 40 A, There will be more current available on the output, but the price you will pay for this is the the output power will be less than the input power. If you are not careful it could be much less. Assuming a conversion efficiency of 85% you would get 1.632 kW of output power at 36 volts which would be a bit in excess of 45 Amperes. Is that what you had in mind? If so be prepared to open your wallet.How to step down DC voltage from 48v to 36v with big current efficiently ?, for about 40a and more
It is possible to make step down module DIY ?, can you give some referenceIs that the input current or the output current? If the input is 48 V @ 40 A, There will be more current available on the output, but the price you will pay for this is the the output power will be less than the input power. If you are not careful it could be much less. Assuming a conversion efficiency of 85% you would get 1.632 kW of output power at 36 volts which would be a bit in excess of 45 Amperes. Is that what you had in mind? If so be prepared to open your wallet.
A quick check reveals that you might have to use 4 or 5 units @ $300.00 ea., in parallel to achieve that objective
You want to design and build this thing as opposed to buying one. Do I have that correct? So have you ever done anything like this before?It is possible to make step down module DIY ?, can you give some reference
Yes... I was made simple SMPS 12v 10aYou want to design and build this thing as opposed to buying one. Do I have that correct? So have you ever done anything like this before?
No, it is for smart home system, load is LED lamp, phone charger, solenoid lock, etcWhat is the nature of the load?
If it's resistive, like a heater, you might be able to use PWM driving some MOSFETs.
Also it is backed up with 48v solar panel and 48v battery, previously we use 36v, but no we decided moved to 48v systemNo, it is for smart home system, load is LED lamp, phone charger, solenoid lock, etc
48v is for distribution, then stepped down at load points
40A seems to be a lot of power for a Smart Home load point.48v is for distribution, then stepped down at load points
No...40A seems to be a lot of power for a Smart Home load point.
Also there is a 3D printer and laser cut at load point, so... 40a isn't really enough, meaybe we can upgrade to 50a later40A seems to be a lot of power for a Smart Home load point.
Good dayNo, it is for smart home system, load is LED lamp, phone charger, solenoid lock, etc
Yes... but I mandatory need big current capacity to sychronize with solar panel that is 36v also wind turbines is 36v, and 36v battery bankSo you don't need a huge current at each load point. That makes a commercial solution easier to find. For your application I would recommend going this way.
Do you know some efficient way ?, it is Chinese generic step down a good idea ?, it's 15a capacity with only about $60, input is 8v-70v DC and output is 10v-60v DCSo you don't need a huge current at each load point. That makes a commercial solution easier to find. For your application I would recommend going this way.
It is basically the same technique used in early backplane computers run on +5 VDC. It was not uncommon for large numbers of original TTL circuit boards to require many 10's of Amperes from the 5 Volt supply. Some bright guys figured out that you could distribute +8VDC and put +5 Volt regulators on each board. Each regulator on a heatsink on the individual boards would do 1.5 Amperes. That is a way to do DC power distribution.Do you know some efficient way ?, it is Chinese generic step down a good idea ?, it's 15a capacity with only about $60, input is 8v-70v DC and output is 10v-60v DC
It is good for using IC like XL4015 in parallel ?It is basically the same technique used in early backplane computers run on +5 VDC. It was not uncommon for large numbers of original TTL circuit boards to require many 10's of Amperes from the 5 Volt supply. Some bright guys figured out that you could distribute +8VDC and put +5 Volt regulators on each board. Each regulator on a heatsink on the individual boards would do 1.5 Amperes. That is a way to do DC power distribution.
by Jeff Child
