Starting with MPLAB X and new hardware
atferrari
Joined Jan 6, 2004
5,028
PIC micros.
Having worked with Win XP and PicStart Plus, always in Assembly, I will be resuming my activity now with Win 10 on my PC, after an almost three years impasse.
Writing in C is out of question.
To avoid wasting time, I would appreciate suggestions on the following:
a) After downloading MPLAB X ver 5.05, have not managed to download MPASM. It seems that I lost my chance when I was finishing the installation. I am at lost here. EDIT/ SOLVED / EDIT
b) Most recommended hardware. I never used a PicKit. I was even planing to buy an ICD3 !!
c) I would like to implement a few old projects that were 100% functional at the time.
d) I intend to continue, for now, focused on the 18F family.
Thanks for your time.
MaxHeadRoom
Joined Jul 18, 2013
30,802
I program in Assembly and so far find MPLAB-IDE far better than MPLAB-X.
If the PIC's you use can be programmed with Pickit2, use this, I have both 2 & 3 just due to some of the later PIC's but where possible I use any that can done with the Pickit2.
BTW, I mainly use XP .
Max.
JohnInTX
Joined Jun 26, 2012
4,787
I program mostly in assembler but use C as well. I would recommend starting with X and ICD-4. MPLAB 8.xx is at end of life even though many prefer it to X - I still use 8.x for legacy projects that don’t warrant a full port. But X is where it is all going and ICD-4 or PK-4 is the latest lower-cost development gizmo. It just gives you a better path for the future. PK-4 currently supports debug headers for the smaller parts. Note that these are new and don’t support all legacy parts yet. Check the docs for the full list.
Sensacell
Joined Jun 19, 2012
3,787
If you don't plan on wading into 'C'- stick with MPLAB 8
MPLABX is full of nightmarish complexity you will not benefit from if writing in assembly.
I wrote assembly exclusively for 20 years, about 2 years ago, I switched over to 'C' - it's just more productive once you get the hang of it.
