Start capacitor
timbers
Joined May 11, 2025
5
I have a Dayton compressor motor that is missing the start capacitor. The motor runs good if I assist it to get started. The model # is 8YJ20B. It is single phase, 3450 rpm, 120v. I cannot locate what start capacitor to use on this motor. Can anyone help me out?
MaxHeadRoom
Joined Jul 18, 2013
30,860
Yes, you should find that anything around from 450 to 500uf + should work, it is only in circuit for a couple of seconds.
Ensure you obtain a genuine start cap,,. regular electrolytics are no good for this application.
timbers
Joined May 11, 2025
5
Likely not that high. Around 70Mfd is common.
OP - does that motor have one or two caps on it (cap warts mounted on top)? It appears to have two, so my guess is, one start and one run cap.
https://offerup.com/item/detail/14c7ce01-793c-3ded-8c62-3a96dc69f790
The motor has 2 capacitors. The run capacitor came with the compressor. The start capacitor is missing. If I give the motor a slight assist, it runs through the cycle until the pressure switch shuts it down. When I attached a start capacitor to the motor it starts right up, runs for few seconds and blows the 20 amp breaker. It doesn't matter which of the 2 wires are connected, it responds the same. Is it possible that run capacitor is wired up to wrong leads?
timbers
Joined May 11, 2025
5
There only 2 posts the red wire and the black wire. I tried both positions with the same result. You could hear the start capacitor click at the same time it threw the breaker.
MaxHeadRoom
Joined Jul 18, 2013
30,860
The start cap requires disconnection during the acceleration period of the motor, this is often done with a centrifugal switch mounted around the shaft, after years of use, it gets weak and often one of a few problems occur with it.
timbers
Joined May 11, 2025
5
So maybe not such a big deal.
