Hi..
I want to design stacked patch antenna by this spec...
Parameter---------Min------------Max-------- Description
arU------0.6------ 1.4------ Aspect ratio for the upper patch
xU-------20mm----68mm--- The x-dimension for the upper patch
arL------ 0.6------ 1.4------ Aspect ratio for the lower patch
xL------- 20mm----68mm--- The x-dimension for the lower patch
tL------- 0.1mm---10mm----Thickness of the lower dielectric layer
tU-------0.1mm---10mm--- Thickness of the upper dielectric layer
εU-------1.0------7.0------ Relative permittivity of the upper dielectric layer (μ_r=1.0)
εL------- 1.0------ 7.0------ Relative permittivity of the lower dielectric layer (μ_r=1.0)
xfeed----0.2mm---10mm----Distance of feed probe from the edge of patch
These are my spec.. want to design stacked patch antenna... plz help me... I am having MATLAB software... If u know the coding plz post here or send to my mail <SNIP>...
Thanks.........
Thanks.........
