SSR resistor
Dritech
Joined Sep 21, 2011
907
Hi all,
I am going to use an Omron G3NA-240B solid state relay to switch a 1100W 240VAC device.
Is there a particular resistance value which I should use at the input therminal of the SSR?
GopherT
Joined Nov 23, 2012
8,009
Hi all,
What does the datasheet for the relay recommend?
30,663
The typical input impedance for those SSR's is around 2-3K.
As per #3 you do not normally require any series resitor.
What are you driving it with?
