I am trying to calculate the Power Dissipation of an SSR #CPC1511. I have been over many possibilities for this calculation and it still remains an electronic mystery. I am feeding 12VDC 3A supply into both a voltage generator circuit and a 555 timer. The generator is set to deliver 100VDC. Using a 750 Ohm, 30W resistor, I should get .133A. The 555 is constructed for 8Hz. I have read that you calculate dissipation for just the SSR which has a total dissipation of 1436mW. Using P=IxIxR with I=.133A and R=2.8 Ohms ("on" resistance per data sheet), P=.05W = 50mW. They indicate that you need to derate dissipation. 85*C-25*C=60*C. 60*C x 14.3mW/*C=858mW. Why do they advertise dissipation at 1436mW when actually it is 858mW ? Does this mean that because the 50mW is well within the range of 858mW, this SSR will not melt down with 100VDC/133mA ?
Others have suggested you have to take into consideration the pulse rate of the 555, and the components down stream of the SSR.
Any help would be greatly appreciated.
