LiPO Power Charging and Power Supply
jtrier_itc
Joined Jun 12, 2026
11
Hello everyone,
I am a bit green on the LiPO Battery ecosystem, have done a lot of searching/reading, and can still use some help. :)
My objective is to power a monitor with an AC/DC power supply while charging an attached LiPO battery pack. Then have the batteries provide power when the power supply is disconnected.
It seems like I should be able to use a battery charging control board to do this, like the XH-M601. But for some reason, I can't find a LiPO power supply that isn't a burst/fast charger, which would ruin the equipment. Is this because the tech is too different and needs to be approached differently?
Any leads or help would be appreciated! Thank you!
sghioto
Joined Dec 31, 2017
8,760
The XH601 is a relay module that connects or disconnects the lipo charger from the battery at user set limits. It doesn't control the charging current.
What voltage level is required for the monitor?
jtrier_itc
Joined Jun 12, 2026
11
Hi Sghioto, I appreciate that!
The equipment has a range of 10v-36v 5A. But I am targeting 12v. The battery is 12v/30A (Marine Battery).
Thank you!
38,932
An LiFePO4 battery can be left at a charge voltage of about 13.6V, where it will charge to about 80-90% of its full capacity.
So you can connect the battery to a current-limited 13.6V supply to both charge the battery and power the equipment at the same time.
No special charge circuitry required.
It's similar to a Lead-acid battery in that respect.
