Would you be interested in talking further about my project? My email address is stevesink@gmail.comfind the number of the detector chip used in the monitor, most have a pin for use in squelch circuit.
You might want to remove your email address and request that some one contact you through the private message system in the allaboutcircuits systemI should have been more specific in my first post. I am looking for someone I can pay to help with this project.
Thanks,
Steve
Thanks. As you might have guessed I am new to this.You might want to remove your email address and request that some one contact you through the private message system in the allaboutcircuits system
Will do once I figure out how to do thatThanks. As you might have guessed I am new to this.
That's an excellent point. Most squelch gates operate by detecting the carrier, not the information encoded in the modulation method. If the carrier is on all the time then more sophisticated methods are required to achieve the required function.many of the baby monitors operate on the same frequencies and modes used on scanners, try to find a scanner that will work with your baby monitor transmitter. also, baby monitors usually transmit all the time, so a squelch would probably not work with one.
You mean by quieting, that the incoming signal, a modulated carrier, swamps any noise in the receiver's passband.and fm recievers use a noise based squelch, a carrier quiets the background noise generated by an fm detector.
No, I don't think so. You've just asked a series of questions to determine the feasibility of an idea. You haven't stepped in anything yet.Thanks guys.
My intention was to leave the "sending unit" in the on position. There will be continuos collateral noise in this location. The "receiving unit"would "tone out" this noise using an adjustable squelch knob. When the event to be monitored activated it would generate a louder noise overriding the squelch control and notify the "receiving unit" via speaker the sound generated by the event mechanism. To far fetched? Have I broken all the rules of electronics?
I will read and continue my education in this field.You mean by quieting, that the incoming signal, a modulated carrier, swamps any noise in the receiver's passband.
