Spoilt for choice
atferrari
Joined Jan 6, 2004
5,026
Damn... I've been watching strange parts and I'm so jealous of folks living in Shenzhen and Japan...
The best and most strange experience on that regard was after signing off from my last vessel in Singapore. With two days waiting for our flight to come back home, I got time to visit the Sim Lim Towers; one of them, fully dedicated to components. Why I bought so few things there, is a mystery to me.
I have some because I've used them in the past, but I consider them a specialty item like a transconductance amp.
The CA3140 wasn't even good for that. I traded an house design that used the CA3140 for an LF351, but that needed help with stability. I think I went with an OP41 with an (OP41 & LT1010) buffer. before that, I used the OP17.
Audioguru again
Joined Oct 21, 2019
6,826
Yes I was wrong, the old CA3140 had an input made with Mosfets, not Jfets.
It was invented by RCA who invented Cmos logic, then the old CA series was sold to Harris then to Intersil then to Renesas of Japan.
Wolframore
Joined Jan 21, 2019
2,619
@AnalogKid this opamp is strange and elusive. The input has to be at the threshold or lower for Q9/10 to conduct. So R2-5 keeping drain higher while source near VCC. Theres gotta be a Vin max thats lower than Vgs. The zeners may help by activating a Inversion. It’s not an audio opamp. Even the output is strange.
Not a standard opamp at all. What have you used it for? It’s cool because its so unusual.
schmitt trigger
Joined Jul 12, 2010
2,211
Indeed, the amount of choices is overwhelming.
What I do, is to have three workhorses which are fine for the vast majority of projects:
-LM358, low cost, plain vanilla general purpose, wide supply range.
-TL072, audio and signal conditioning, widely available.
-TLC2272, low supply voltage, R2R.
Of course if I require a specific parameter like ultra low Vos, then I’ll search for chopper amps.
MisterBill2
Joined Jan 23, 2018
28,160
OK, so now your first selection step must be to decide what the requirements are, and probably how much you are willing too spend. Then , if they still have selection guides, go online to your preferred brands selection guide. Of course now the package is a big part of the deal. The last opamp that they ordered for the project that I was working on had several variations of pin-out available. Which pin-out was identified by the second letter after the part number. What a royal pain, just consider the possible production logistics problems. And this was a single SMT opamp about 0.1 inch square. Our specific requirements were the automotive temperature range and being very stable. Of course our other requirement was reliable availability, since it would go in a small sensor with 5 sensors on every car built by that company. Reliable availability is not a hobby requirement.
Wolframore
Joined Jan 21, 2019
2,619
Reliable ability, kind of burned us last time, we had to special order 5,000 switches when we only needed about 100 for the test run because the client specified NKK... ugh... then they complained to me about it...
