Hi guys!
today I was thinking about a scheme of a splitter made with a BJT. In the two outputs the circuit allows to obtain two signals out of phase by 180 ° between them. Actually I found the scheme on the net and I replaced the BJT to get better performance between the two output phases. The problem is that on LTspice the two output signals are of the same amplitude while in the other software it does not happen. In fact on the first output I get 5.93mV while in the second I get 122uV. So the question is: Why do I get different results with the same pattern? And above all if there is an error what should I do to have two equal amplitudes on the two outputs? Thank you.
EDIT: I replaced the first image because the measured output values were missing.
