Spice Model for LM2917
GigiaBaffa
Joined Feb 28, 2016
4
I would like to use LM2917 in Multisim but the component is missing.
I'm trying to make it using component wizard but at some point it asks me for model. I can load a spice model (user defined) from file but only .cir files are accepted.
I found in this topic LTspice models but they are in asc/asy extension.
GigiaBaffa
Joined Feb 28, 2016
4
Why .lib?
It asks me .cir.
Anyway I tried to load LM29x7.sub renamed as LM29x7.lib.
It says to me The SPICE file must be a text file. Continue to load this file?
I select Yes and the model is loaded but when I click Next I get another warning
GigiaBaffa
Joined Feb 28, 2016
4
Cannot edit the post to add some text.
It seems that inside sub file there are four models.
Tried to delete three of them but when clickink Next I get another warning:
SPICE Netlist Warning, element 'Z68:LM2907-8': Unknow model parameter 'vpk', this parameter will be ignored. Do you want to continue?
GigiaBaffa
Joined Feb 28, 2016
4
Thanks for help.
I'm trying to simulate this circuit:
I don't know if I have mapped pins correctly since inside datasheet there is no an explicit pinout.
When I start simulation i get a Netlist error.
I attached the multisim file.
