SPI CHIP SELECT IN FPGA
AraugelLearnings
Joined May 13, 2022
How many chip select we can use for one SPI controller in FPGA? is there any limitation!
I'm using Intel stratix 10 GX FPGA it supports only 4 SPI , I need to use more for that i thought of using more than one chip select.
Regards,
Aravind D
simozz
Joined Jul 23, 2017
170
I don't know Stratix architecture, but in general there aren't limitations on the slave devices number.
You might consider implementing your own SPI controller with many CS as you want.
s.
drjohsmith
Joined Dec 13, 2021
1,661
Regards,
Aravind D
When you say it supports "only 4"
Where do you read that from.
If I have the right one , these FPGAs have a hard processor and a programmable side.
The hard processor , will have a spi controller block built in , and it will Have a pre defined number of chip select pins on that controller.
But , using the fpga side of the chip, you can add your own spi controller, either from the built in up, or a open source one or your own design .
Other options include updating the spi driver to use the gpio pins as chip selects and ignoring the built in chip select pins.
