I just swapped the njm4151 with a ka331 without any changes to the circuit and it worked flawlessly. these two chips are fundamentally identical. Mouser has nearly 2000 of the njm's in stock.
Again, it is something to be aware of, should parts become hard to get. But I don't think that is going to be an issue from what you have said. I have added it here primarily to keep the information available for future experimenters.Source: anatekcorp.com
QUESTION NO. P41403-7: What is the cross for RC4152 Voltage to frequency converter?
RC4152 has the same pinout as LM331, so you could use LM331 or LM331A. But the reference voltage at pin 2 is typically 1.9V for LM331, versus 2.25V typically for RC4152, so the resistor value used off pin 2 of a LM331 would need to be decreased correspondingly from that used with a RC4152, to obtain the same frequency, as a circuit with an RC4152 would provide.
Hi again John. I am from here in Central Maine. and let me tell you, its friggin cold here too.Good morning. Although I have a couple of the 4151 chips, I have not actually used them in any project. Some possibilities for the cause of that problem come to mind, but before I make a fool of myself, lets look at a few things.
Pin1 of the FVC supplies a max of 138 uA (from the 4152). There is also ripple on that output pin. Input current needs should be quite low, but there is a low pass filter on the input (resistor with capacitor to ground). That would shunt the part of the voltage you are measuring that is ripple to ground.
1) Have you looked at the output of the F/V converter with your scope? Does it sag when you attach the scope. Is there ripple?
2) When you attach the F/V to the V/F, look at the input pin on the V/F with your scope. If your scope caused voltage sag, then look at it only with your meter. If there was ripple, it should be gone. If not, how much in volts is there?
3) Do both sections have a common ground? They should. I assume you are simply taking the V_out and connecting it to the V_in filter. If not, please post the schematic of how you are doing it. Just to double check, you are using a capacitor input to the F/V converter, right?
4) If it is a loading problem, you can get around that with an op-amp between the two stages. But let's see what's going on at the input first.
In the meantime, I have been working on another option using the CD4046 chip. Had it working at X4 last night down to about 3Hz input. That was just a first try and I hadn't done any calculations for adjusting the frequencies. Not trying to confuse you. Just looking at a possible PlanB; although, I think that is very unlikely to be needed.
It is just too darn cold here to do anything but goof off. What part of the world are you in?
John
I am interestedin in this Kit Debe. I know I am probably reinventing the wheel here, but I am having fun with it. I originally approached it with a Parallax Basic Stamp, (which has a PIC on it) but I found with my rudimentary program that it would pause for something like 200ms after every cycle, and that was just too long especially when my speed measurement step was only like 17ms. Could some other microcontroller do the job better? probably, but I am vested in my current solution so I am going to stick with it a little longer yet.Be very interesting to see your finished project & how you went about it. Will post a bit of info on a kit i built a few years ago for a client, who had changed a diff in his car & the speedo was a long way out. It worked quite well. It was published by Silicon Chip & the kit was Jaycar & still avalable. & used a PIC chip.
they might be for some, but I have had virtualy Zero experience with them, so they seem a bit daunting to me as well.Yeah, micros are so easy, it is almost like cheating. John
the circuit doesnt actually need to respond to anything lower than about 8 hz. since speedos dont even read till ten miles per hour, an 80" circumference wheel driving a 4 pulse per rotation sender is actually 8.8hzI am anxious to hear how the new generator works. I don't think that is the problem, though. It's still worth a try. If you can test the voltages and scope on the interface, I would appreciate it. At least that bit of knowledge might be helpful in the future.
The CD4046 method (Plan B) I mentioned has been working fine. It locks right onto the signal. I get pretty linear 4X results with input from 0.5 Hz (my generator is lousy and unstable at that frequency) to 160 Hz. That's probably fast enough for a VW bus, but it can be taken higher, if needed.
John
The earliest op-amps were designed for supplies that provided + and - voltage (e.g., the 741). That is so a sinewave or other AC could be amplified on both the positive and negative parts of the cycle relative to ground. Also from the very beginning, methods were used to obtain "split" supplies from single supplies using resistors. Single-supply op-amps have the splitting (or negative voltage generation) built in. They work the same, but are a little easier to hook up. Your circuit doesn't involve any negative voltages, so a single-supply op_amp will be the easiest for you to hook up.- this might seem like a laymans question, but why would an op-amp NOT be a single supply?
by Aaron Carman
by Jake Hertz
by Jake Hertz
