Hello Ladies and Gentlemen
I just completed a project of getting an electronic speedometer to work with an alternate transmission in my 1986 Mercedes 560SL. You can read about that project at this link.
https://forum.allaboutcircuits.com/...magnetic-speed-sensor-for-speedometer.156292/
Now with that complete its time to move on to what lies ahead and that will be changing the rear end gear ratio which will require re-calibration of the electronic speedometer.
To begin with I am well aware of the off the shelf frequency converters that are available to do this sort of thing externally. And it was my intent to use one of those until I read an article on the European version of my speedometer which was adjustable. So it got me thinking that I could make mine adjustable, probably just by changing one resistor. I have attached two pictures, the first is the European version of the Mercedes speedometer and the second one is my speedometer. The part circled in the first picture is the pot that is adjusted to calibrate the speedometer on the European version. Notice my speedometer is missing that part and there appear to be two resistors in its place along with slight changes of other parts in the vicinity.
So my question is how might I be able to figure out how to make the USA spec speedometer work like the European version shown in the first picture. I have a spare US spec speedometer to play with. I do not have access to a European speedometer.
