I know that USA it is produced in small quantities, but I have badly lost the USA factory name what I collected in one German exhibition.
That is special pulse transformer of 1 nsec 60 kV peaks of about 4 kW, wound on the special toro-core, so that in four places the braid is cut but inner wire is still insulated. It is actually the power source for some high laser, costing rather much. And I have two of such with the same defect - burned this coaxial winding.
Originally there stays silicon rubber insulation d=9mm and inner wire d=1,0mm consisting of silver-coated 7-wire litcendrath. The outhern d over braiding is 13mm. Need for such coaxial cable is 2 pieces of 3 meters long.
I have tried to use the normal antenna coaxial cable instead (like RG8u), all the 10 mm cables was burned in the first second, but the 18 mm I had no enough free place, and them are heavily too hard to make a winding of rather small diameter of 60 mm. Thus, the silicon rubber and litcendrath both are must-to-be, but insulator diameter is willed even to be 10 or 11mm to avoid the burn.
So, may someone be able to give a hint who are producing such coaxial cable of very high voltage?
The impedance, seems, have no a large meaning, however geometric relations makes me think that is 75 Ohm.
Foam filled cables are hardly improper.
Copper-pipe in the middle is even more improper.
I found one Rowe Industries R1006-1 High Voltage Coaxial Cable 50 KVDC but it have a 50 Ohm.... I am not much sure is it so innocent or not, when high power tyrathron is pushing the 10 kV pulse over him and he is four-folding the pulse voltage, but resulting unipolar peak is going by transmission cable to gas-discharge lasing tube.
