Ok, that's great news!Yes i cycled power after programming it and then it started running what configuration I had programmed.
So you're telling me that the device runs the new configuration, but the LED's are still lit?I'm now pretty sure the LEDs are supposed to be offline when the board is in standby,found this in the Manual.
Is the new configuration you're running from flash the same as the one you programmed via JTAG? Did the LED's remain on after programming your configuration by JTAG?The cathode of each LED connects to ground via a 270Ω resistor. To light an individual
LED, drive the associated FPGA control signal High, which is the opposite polarity from
lighting one of the 7-segment LEDs.
Ok, I'm confused. You said your configuration was running from flash. If you unplug and replug the board, your configuration is still in flash, and it should run in you device.The 8 LEDs are lit up when the board isn't running any configuration. Any configuration that I load into it will run as expected(if i'm not using the LEDs they will be off) but after I press the reset button or simply unplug and replug the board all of the 8 LEDs will be lit up.
I understand. That's what we're trying to get to the bottom of.LE: And I've seen boards like mine plugged in and the LEDs were off by default with no configuration loaded into them.
