Source Transformation
p75213
Joined May 24, 2011
70
Hi Guys,
I would appreciate if somebody could give me a hand with the attached exercise. It's easy enough to solve using nodal analysis but I am feeling a bit stumped trying to solve it using source transformation.
p75213
Joined May 24, 2011
70
Well I can't replace the 4A current source with a voltage source because then current ix disappears. If I replace the dependant voltage source with a current source I get a dependant current source of 2ix/5 A parallel with a 5 ohm resistor. I cant combine the 5 and 10 ohms resistors as current ix disappears.
I am pretty much stuck at this point.
Jony130
Joined Feb 17, 2009
5,599
You are doing good job with the problem.
You can not simplifier the circuit more. So all you have to do now is to star finding Ix.
p75213
Joined May 24, 2011
70
It's easy enough to then find ix using nodal analysis, however I can't see the point as it was simpler to do this first up without bothering with the source transformation.
