Source equivalence problem
hunterage2000
Joined May 2, 2010
487
Can someone tell me how I would go about finding the voltage through R5 using the source equivalent method. I still dont really understand this method.
hunterage2000
Joined May 2, 2010
487
Yeah but first reducing the amount of sources by combining the current sources in parallel and voltage sources in series.
reduce all the sources to one source and one resistance.
Jony130
Joined Feb 17, 2009
5,599
So first you need is to disconnect R5 and then find Vth voltage.
To find Vth we could use superposition
Vth'1
Vth'2
Vth = Vth'1+Vth'2
Next we replace all voltage sources with short circuits, and all current sources with open circuits.
And calculate the resistance between terminals A - B
hunterage2000
Joined May 2, 2010
487
The question says determine the Thévenin equivalent circuit of the above network using the “source equivalent” method. Hence calculate the load voltage vL.
I assumed that you would reduce the circuit to one source with one resistance.
Georacer
Joined Nov 25, 2009
5,182
They is essentially the same, but I see two ways to solve this.
You can use the supperposition theorem to find the components of the voltage across the R5, nullifying all the sources but one each time. I trust you know how to do this.
The other way, which I think is what your tutor wants you to do, is to break the circuit to smaller pieces, merging all the sources, two at a time.
For example, starting from the left, find the Norton equivalent of R1 and V1. This will give you a resistance and a current source in parallel. That current source will be parallel with I1 and those can be combined.
Work this way, switching between Norton and Thevenin equivalents, until you reach R5.
Is that clear?
hunterage2000
Joined May 2, 2010
487
this is what Im stuck with. It says parallel sources can be combined so from the start can I1 and I2 BE combined to be 6.6m amps?
if so can you convert all voltages in series into a current source and add them together?
hunterage2000
Joined May 2, 2010
487
nice one mate I'll have a look tomorrow. That example I posted was the only thing I got so thats why Im a bit puzzled with the bigger examples.
