Sound from ultrasound (no sound)
Alec_t
Joined Sep 17, 2013
15,166
the powers I require are only to be able to penetrate the layers of soil (20cm) but there is nothing dangerous in any case
Are you sure? Ultrasonic energy is used by surgeons to break up eye cataracts and kidney stones. If you haven't already done so I suggest you do some research to find out the power levels involved. Ensure energy levels in your use of piezo transducers will be well below those surgical levels.
Drellk
Joined Nov 30, 2023
24
that procedure is called ablation and uses very high frequencies, while I use 20-40 khz and even low powers. However there is the problem of acoustic impedance, how can I solve it? that is, when ultrasound passes from air to ground it is highly reflected, how can I reduce this effect?
