Sondring batteries together - how can it be done?
Rune2504
Joined Jun 18, 2017
12
Hello AAC
I am trying to sold these batteries together, but I don’t know how to sold on the button and top of the batteries. The soldering tin won’t stick with the wire to it. I really hope some of you can help me with this problem, thanks :)
ericgibbs
Joined Jan 29, 2010
21,649
hi Rune,
I have end soldered to NiCd and Alkaline, but would not consider soldering to a Lithium battery, it is a very unforgiving metal when heated.
Will those cells fit into a regular battery holder.?
E
Rune2504
Joined Jun 18, 2017
12
Oh, yes I guess, so what you recommend me is to find some battery holders, ofc., didn't even think about that. It's because I took a Power Bank and wanted to add the old laptop batteries to it, but yea, as you say I should get some battery holders.
MaxHeadRoom
Joined Jul 18, 2013
30,885
There are some links out there to some that have made simple capacitor discharge Stud Welders, this is how the manuf. do it.
The problem with soldering, is getting sufficient heat on the terminal to bond the strip.
Max.
38,947
I soldered wire to a bunch of NiMh batteries without problem by first putting some rosin flux on the battery ends and wire.
ericgibbs
Joined Jan 29, 2010
21,649
I used plumbers paste, a bit aggressive, it works, but its important that you thoroughly clean the joint afterwards.
Use a 60Watt iron with a chisel tip in order to heat the joint area quickly.
