[SOLVED] Technics SU-V3 speaker relay not popping
sghioto
Joined Dec 31, 2017
8,745
I would replace D503 at this point.
Normally for diode checks one lead of the diode should be lifted from the circuit board when testing.
sghioto
Joined Dec 31, 2017
8,745
Okay so Q501 has: B: -0.69 C: -1.5 E: -0.69
And Q502 has B: -1.5 C: -6.67 E: -6.67
Or perhaps positive numbers, unsure on meter leads way-aroundness when testing to chassis / GND
When you have time could you recheck those voltages on Q501-502 please. Make sure the negative lead of the meter is grounded.
Also DC voltage readings on capacitors C502 and 504.
gaber2611
Joined Mar 14, 2013
331
Hey folks I saw some other threads here about this amp and similar issues and I'm at the end of what I can understand by myself.
I have an SU-V3 with the speaker relay not closing off after power on, however when I manually close the contacts I get good sound on the speakers.
I've been playing around and found the following:
The relay seems to be receiving 40vdc,
And
When I investigate SVITA7317p, I get strange readings that don't match any scenario in the service manual:
1: -0.8v
2: 0v
3: 0v
4: 0v
5: +0.8v
6: -40v
7: 0v
8: -40v
9 -3v
The -40vdc readings seem out of place
I also noted when I accidently bridge legs 4 and 5 on the SVITA7317P, the relay closes, so it doesn't seem like a faulty relay
Any help would be appreciated
Where the service manual you talk about?
dimethyltechtamine
Joined Nov 13, 2024
26
Show a picture of your amp. How it is now when you are taking measurements
Acessesing the board like so, it has an access panel I removed
Will check these after work, thanks
dimethyltechtamine
Joined Nov 13, 2024
26
check
Sounds good.
Capacitors: C504 has 198mV. C502 has -18mV. This is with amp off, and with amp on:
504 has 1.5v
And 502 has: 0.7v AC. Unable to get DC reading
Q501:
B : 1.5v
E : 1.5v
C : 0.68v
And Q502:
B : 0.68v
E : 0.7v
C: 1.5v
This is all I have time for tonight, but I will be around tomorrow. Thanks again for the help
dimethyltechtamine
Joined Nov 13, 2024
26
Update: with a lot of guidance from sghioto, we found D501 to be shorted. After replacing both D501 and D503, the relay clicks on after 5 seconds as it should :)
Much thanks team, very happy to have this amp working
