[SOLVED] Technics SU-V3 speaker relay not popping
dimethyltechtamine
Joined Nov 13, 2024
26
Read the resistance between pin8 and pin9 with the amp OFF and between pin3 and pin7 please.
Pin8 and pin9: bouncing around alot, but in the range of Mohm and Kohm, so very high. Seemed to settle on 0.36Mohm
Pin3 and pin7: gives about 1.2 ohm, which is about the same as when I short my meter leads, so I would say it's closer to 0 ohm
dimethyltechtamine
Joined Nov 13, 2024
26
Now I suspect resistor R510 a 180K between pin8 and pin9.
Do you see any bad solder connections on those pins and components?
Do you have a resistor to jump across pin8 and 9 to test with?
Solder looks okay around R510, and is reading at the right resistance
What kind of resistor would I want to be jumping with? I can salvage one from some boards I bought home from work to practice soldering on
sghioto
Joined Dec 31, 2017
8,750
I think you mean 42 millivolt on pin 8 but no matter the problem is that 0.67 volt on pin 1 it should be appx -0.8 volt.
Short pin1 to pin 3 and to see if the relay comes on.
dimethyltechtamine
Joined Nov 13, 2024
26
Yep just double checked pin 8 and it is mV.
Shorting pin1 to pin3 starts the relay, I also found that shorting pin6 to pin7 does too (found incidentally)
Edit: let me try again, had my pin order the wrong way around. (Fixed now)
sghioto
Joined Dec 31, 2017
8,750
OK then the problem might be associated with Q501 and Q502.
Can you get voltage measurements on all leads of those transistors?
dimethyltechtamine
Joined Nov 13, 2024
26
Okay so Q501 has: B: -0.69 C: -1.5 E: -0.69
And Q502 has B: -1.5 C: -6.67 E: -6.67
Or perhaps positive numbers, unsure on meter leads way-aroundness when testing to chassis / GND
sghioto
Joined Dec 31, 2017
8,750
Those readings don't match the schematic especially on Q502.
See what the voltage reads on both sides of diode D501. Make sure the polarity of the meter leads is correct.
dimethyltechtamine
Joined Nov 13, 2024
26
It's reading 0.67V ac on the anode and 0.97V ac on the cathode side
Edit: I'm learning now that my multimeter has a diode mode, let me figure this out
dimethyltechtamine
Joined Nov 13, 2024
26
I think the diode is open edit:shorted?
Using diode mode on multimeter and Getting 0.7 voltage across with black lead on anode and red lead on cathode and 0.45 with leads the other way around.
so it is passing current both ways?
