[SOLVED] Technics SU-V3 speaker relay not popping
dimethyltechtamine
Joined Nov 13, 2024
26
Hey folks I saw some other threads here about this amp and similar issues and I'm at the end of what I can understand by myself.
I have an SU-V3 with the speaker relay not closing off after power on, however when I manually close the contacts I get good sound on the speakers.
I've been playing around and found the following:
The relay seems to be receiving 40vdc,
And
When I investigate SVITA7317p, I get strange readings that don't match any scenario in the service manual:
1: -0.8v
2: 0v
3: 0v
4: 0v
5: +0.8v
6: -40v
7: 0v
8: -40v
9 -3v
The -40vdc readings seem out of place
I also noted when I accidently bridge legs 4 and 5 on the SVITA7317P, the relay closes, so it doesn't seem like a faulty relay
Any help would be appreciated
sghioto
Joined Dec 31, 2017
8,756
Measured from ground it should read .7 volt on the base and close to zero on the collector of Q706 when the relay is activated.
Does the LED blink for several seconds when first powered ON?
dimethyltechtamine
Joined Nov 13, 2024
26
Im unable to find Q706 anywhere on the schematics... Am I missing something?
I will check about the LED when I get home, I do know the "class a" sign lights up
[/QUOT
sghioto
Joined Dec 31, 2017
8,756
To start, connect the negative lead of your meter to pin3,4 or pin7 which should be ground on the SVITA7317 chip.
With the amp OFF place the other lead on pin8.
Turn on the amp, the voltage should rise to appx 1.3 volts in 5 seconds and activate the relay.
See what happens.
35,225
If you have the schematics of the amp, measure the DC voltage at the amplifier output, not at the speakers.
If the DC voltage exceeds a given threshold, the relay will not be activated. This is a safety feature to prevent blowing your speakers.
dimethyltechtamine
Joined Nov 13, 2024
26
Would this mean measuring at the speaker terminals (without speakers attached)?
I have the schematics but am still learning to interpret
I forgot to mention, and I'm unsure if it's important but when I manually close the relay with amp on and speakers connected I get good sound coming through
35,225
No. The purpose of the relay is to connect to the loudspeaker only if it is safe to do so.
You don't need to disconnect the speakers but it would not hurt for you to disconnect them.
You need to take the voltage measurements inside the amplifier at test points TP1 and TP2 as shown for the LEFT channel.
You need to do the same at the RIGHT channel at TP3 and TP4 (all voltages with respect to ground or chassis).
You can get the same information by measuring the voltage on the legs of R349 and R350. Any side of the resistor will do.
sghioto
Joined Dec 31, 2017
8,756
Have you had a chance to measure the voltages on the chip as I suggested?
It's important to take these readings to start eliminating what's working.
dimethyltechtamine
Joined Nov 13, 2024
26
To start, connect the negative lead of your meter to pin3,4 or pin7 of the SVITA7317 chip.
See what happens.
Just tried this, I'm getting 42.7mv DC between pin 3 and 8, both immediately and after 5 seconds. My original measurement on pin 8 of 40v may have been a misreading of the meter by me
Thank you, I appear to have no, or very little (reading around 1.2mV) on these resistors. (R349 and R350)
sghioto
Joined Dec 31, 2017
8,756
I suspect that capacitor C503 on pin 8 is defective/shorted.
EDIT: correct capacitor is C503.
