SOLVED - SPI Clock and Modes
Sparsh45
Joined Dec 6, 2021
143
I am still confused after reading the general SPI communication documents
The SPI always sends and receives a byte at the same time. at the end of the 8 pulses they will completely exchange byte.
SPI mode depends on clock edge and clock polarity
The edge of the clock can either rising or falling.
The polarity of the clock can be high or low.
If I select High Polarity and Rising edge for master and slave.
On which edge, data will in and which edge, data will out ?
Sparsh45
Joined Dec 6, 2021
143
hi 45,
The Master and Slave have to be set to the same Mode.
Look at this link, simple breakdown of the methods.
Note the RED vertical data xfer lines.
E
https://dlnware.com/theory/SPI-Transfer-Modes
When master and slave is configured for High Polarity and Rising edge.
My understanding, data is entered on one edge, then it is out on the other edge.
Sparsh45
Joined Dec 6, 2021
143
Setting CPOL = 1 & CPHA=1 in the REST state means the data is Clocked on the Rising edge.
E
Thanks for the posting picture.
If I'm not mistaken the SS/CS signal should be at the top of the picture because the SS/CS signals start the SPI communication. When the transaction starts it is set to low and when the transaction ends it is set to high.
I see the datasheet of the pic microcontroller, it has four modes and can be configured for any of them.
Does SPI mode depends on the slave device which mode it supports ? We can configure the pic uC for the mode it supports.
ericgibbs
Joined Jan 29, 2010
21,550
hi,
The Master is so called because it controls all the data exchange signals sent to the Slave.
The Master has to be set to suit the Slave, which usually has it Mode fixed, but some Slave peripherals can be self programmed to alternate Modes,
BUT Master and Slave must be set to the same Mode.
E
Sparsh45
Joined Dec 6, 2021
143
How far micro and slave devices can be connected? So far I see connecting in a short distance only.
Can the distance between these two be 1m, 10m, more then 30m.
I know this question doesn't make much sense. anyway Is there a reason why it can't be connected over long distances. is it possible or is it not possible to connect over long distance ?
https://www.ti.com/lit/an/slyt441/slyt441.pdf
ericgibbs
Joined Jan 29, 2010
21,550
What happens on the falling edge of the clock ?
Does Slave clocks data in on the falling edge of the clock ?
Hi S45,
Are you reading my posts.? ??
I posted:
The data is captured on the clock's low-to-high transition
The data is internally propagated on high-to-low clock transition.
No, it's already been Clocked on the Rising/Leading edge of the clock.
Read the Data Transmission section of this link.
https://embetronicx.com/tutorials/tech_devices/spi-serial-peripheral-interface-protocol-basics/
