[SOLVED] How to set the clock time? (Lost instructions)
Alec_t
Joined Sep 17, 2013
15,152
I bought a kitchen timer identical in appearance to the pic below, but have lost the instructions for setting the clock time on it. Anyone know how? Or where I can get the instructions?
The Mode button toggles between a clock function and a count-down/up timer function. No problem with setting the timer.
There are no markings to identify the make or model.
I've tried various combinations of button presses and holding buttons down for varying times, but with no success.
Alec_t
Joined Sep 17, 2013
15,152
That's the beast (albeit a named brand, but probably off the same oriental producion line ). Thanks for the link, Eric. Unfortunately it shows only the timer operation mode; not clock setting.
Edit:
PROBLEM SOLVED!! Removing and re-inserting the battery did something, so now clock setting is enabled using the H,M,S buttons.
