[SOLVED] nRF24L01
wernerdejong1972
Joined Sep 10, 2021
12
Hi all
I´m trying to get to arduinos to communicate together througt a nRF24L01. On the receiver side I want to turn the builtin LED to turn on every time I press a button on the transmitter. Furthermore I want to show a message on the Serial monitor that tells me the state off the button.
The part with the serial monitor works as planned but the builtin LED doesn´t turn on. What am I doing wrong?
C:
//RECEIVER
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";
boolean button_state = 0;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(9600);
  radio.begin();
  radio.openReadingPipe(0, address);   //Setting the address at which we will receive the data
  radio.setPALevel(RF24_PA_MIN);       //You can set this as minimum or maximum depending on the distance between the transmitter and receiver.
  radio.startListening();              //This sets the module as receiver
void loop()
  if (radio.available())              //Looking for the data.
    char text[32] = "";                 //Saving the incoming data
    radio.read(&text, sizeof(text));    //Reading the data
    radio.read(&button_state, sizeof(button_state));    //Reading the data
    if (button_state == HIGH)
      Serial.println(text);
      delay(5);
      digitalWrite(LED_BUILTIN, HIGH);
    else
      delay(5);
      digitalWrite(LED_BUILTIN, LOW);
  delay(5);
Moderator edit: added code tags like this [code] ... your code... [/code]
wernerdejong1972
Joined Sep 10, 2021
12
Sure :)
C-like:
// Transmitter
#include <SPI.h>
#include <RF24.h>
const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button_pin = 2;
void setup() {
pinMode(button_pin, INPUT);
radio.begin();                  //Starting the Wireless communication
radio.openWritingPipe(address); //Setting the address where we will send the data
radio.setPALevel(RF24_PA_MIN);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
radio.stopListening();          //This sets the module as transmitter
void loop()
button_state = digitalRead(button_pin);
if(button_state == HIGH)
const char text[] = "Your Button State is HIGH";
radio.write(&text, sizeof(text));                  //Sending the message to receiver
else
const char text[] = "Your Button State is LOW";
radio.write(&button_state, sizeof(button_state));  //Sending the message to receiver
delay(1000);
wernerdejong1972
Joined Sep 10, 2021
12
When I remove:
radio.begin();
and add
in setup, the builtin LED turn on. Otherwise it´s impossible to get the LED to turn on.
Ya’akov
Joined Jan 27, 2019
9,143
Try adding a delay at the end of the on button state block, just to check.
C++:
      delay(1000);
wernerdejong1972
Joined Sep 10, 2021
12
Do you mean this?
C-like:
      //Serial.println(text);
      delay(1000);
    else
      delay(1000);
(didn´t work either...)
Ya’akov
Joined Jan 27, 2019
9,143
Yes, that's what I meant. So I have this straight, when the serial code is uncommented, it does write to the serial monitor, correct?
wernerdejong1972
Joined Sep 10, 2021
12
" SPI uses pin 13, so you can’t really use the built in LED while using SPI. "
could this be the solution? I´m not sure, because I´ve also tried pin3 without luck.
Ya’akov
Joined Jan 27, 2019
9,143
See above. pin 13 is hardwired to the builtin LED. You will ahve to put an external led on a different pin to make it work.
