[SOLVED] nRF24L01
wernerdejong1972
Joined Sep 10, 2021
12
Hi all
I´m trying to get to arduinos to communicate together througt a nRF24L01. On the receiver side I want to turn the builtin LED to turn on every time I press a button on the transmitter. Furthermore I want to show a message on the Serial monitor that tells me the state off the button.
The part with the serial monitor works as planned but the builtin LED doesn´t turn on. What am I doing wrong?
C:
//RECEIVER
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";
boolean button_state = 0;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(9600);
  radio.begin();
  radio.openReadingPipe(0, address);   //Setting the address at which we will receive the data
  radio.setPALevel(RF24_PA_MIN);       //You can set this as minimum or maximum depending on the distance between the transmitter and receiver.
  radio.startListening();              //This sets the module as receiver
void loop()
  if (radio.available())              //Looking for the data.
    char text[32] = "";                 //Saving the incoming data
    radio.read(&text, sizeof(text));    //Reading the data
    radio.read(&button_state, sizeof(button_state));    //Reading the data
    if (button_state == HIGH)
      Serial.println(text);
      delay(5);
      digitalWrite(LED_BUILTIN, HIGH);
    else
      delay(5);
      digitalWrite(LED_BUILTIN, LOW);
  delay(5);
Moderator edit: added code tags like this [code] ... your code... [/code]
wernerdejong1972
Joined Sep 10, 2021
12
Sure :)
C-like:
// Transmitter
#include <SPI.h>
#include <RF24.h>
const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button_pin = 2;
void setup() {
pinMode(button_pin, INPUT);
radio.begin();                  //Starting the Wireless communication
radio.openWritingPipe(address); //Setting the address where we will send the data
radio.setPALevel(RF24_PA_MIN);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
radio.stopListening();          //This sets the module as transmitter
void loop()
button_state = digitalRead(button_pin);
if(button_state == HIGH)
const char text[] = "Your Button State is HIGH";
radio.write(&text, sizeof(text));                  //Sending the message to receiver
else
const char text[] = "Your Button State is LOW";
radio.write(&button_state, sizeof(button_state));  //Sending the message to receiver
delay(1000);
wernerdejong1972
Joined Sep 10, 2021
12
When I remove:
radio.begin();
and add
in setup, the builtin LED turn on. Otherwise it´s impossible to get the LED to turn on.
Ya’akov
Joined Jan 27, 2019
10,259
Try adding a delay at the end of the on button state block, just to check.
C++:
      delay(1000);
Ya’akov
Joined Jan 27, 2019
10,259
OK. More quick troubleshooting. Comment out the serial write, just leave the digital write code in the conditional block.
wernerdejong1972
Joined Sep 10, 2021
12
Do you mean this?
C-like:
      //Serial.println(text);
      delay(1000);
    else
      delay(1000);
(didn´t work either...)
Ya’akov
Joined Jan 27, 2019
10,259
Yes, that's what I meant. So I have this straight, when the serial code is uncommented, it does write to the serial monitor, correct?
wernerdejong1972
Joined Sep 10, 2021
12
" SPI uses pin 13, so you can’t really use the built in LED while using SPI. "
could this be the solution? I´m not sure, because I´ve also tried pin3 without luck.
Ya’akov
Joined Jan 27, 2019
10,259
See above. pin 13 is hardwired to the builtin LED. You will ahve to put an external led on a different pin to make it work.
