[Solved] How to Lower Threshold of OTS Schmitt Trigger?
johnyradio
Joined Oct 26, 2012
615
Not repetitive. It's a varying DC voltage which quickly (milliseconds) rises up from zero to max 5v for a few minutes, then fades back to zero over the course of about 20 seconds.
Alec_t
Joined Sep 17, 2013
15,156
I'd rather lower both thresholds, and have standard hysteresis
You can lower the thresholds (albeit with increased hysteresis) by biasing the Schmitt input with a resistor to the +ve rail, like this :-
If you want to lower both thresholds and reduce the hysteresis you can make a custom Schmitt trigger from a couple of non-Schmitt inverters as below :-
The ratio of R2/R3 sets the hysteresis amount. Here it's about 1%. R1 pulls the thresholds low.
johnyradio
Joined Oct 26, 2012
615
I was trying to find out why you are constrained to using a simple low accuracy Schmidt logic gate
@danadak Low accuracy in what way?
@Alec_t and @ericgibbs fantastic. Both of your solutions seem great, tho's technically Alec's version uses Schmitt's as requested. Alec's version seems to win on low-parts count, tho' i'd like to see how stripped-down the LM393 can get (eliminating parts), while matching functionality.
Alec, where's the triangle coming from in yours? Is that the item marked 'pulse'?
danadak
Joined Mar 10, 2018
4,057
Basic circuit -
Tool to calc Rs -
https://www.daycounter.com/Calculators/Comparator-Hysteresis-Calculator.phtml
http://sim.okawa-denshi.jp/en/compkeisan.htm
The problem using CMOS gates is accuracy of trip points pretty sloppy, even with precision resistors.
With a comparator or OpAmp its primarily determined by R tolerance. In high precision designs
offsets and G....... will also contribute to error, but your design, using an OpAmp or Comparator,
I think just R precision will determine.
Regards, Dana.
johnyradio
Joined Oct 26, 2012
615
but your design, using an OpAmp or Comparator, I think just R precision will determine.
Thx for circuit! But what's the A part? CMOS? Or OpAmp/Comparator? What's "your design"?
