[SOLVED] Counter IC does not count
gelzky
Joined Dec 7, 2021
86
hi g,
That's great, at least you know the 4026/LED is now working.:)
Try this, connect the sensor to the input pin #1 of the 4026, measure with a voltmeter the voltage on pin #1 while you move your hand about in front of the sensor, what voltage do you measure.?
E
I don't know if I'm doing it right i got 2,173?
ericgibbs
Joined Jan 29, 2010
21,568
hi,
A high voltage of 2.173 volts is too low to clock the 4026.
Does always stay at 2.17V , never changing.?
Modify the circuit as I have shown in that diagram. post #20
E
gelzky
Joined Dec 7, 2021
86
hi,
E
okay thanks, it does change sometimes but the max is 2.89V. what is the resistor value 4k7?
Ian0
Joined Aug 7, 2020
13,278
It's a PULL-UP resistor (see post #5). It's value doesn't matter very much (anything from 1k to 100k will probably work), but without it the output cannot produce a logic high.
35,171
Your resistors are a mess. You are in danger of creating a short circuit and blowing out the LED. Place the seven resistors all in a neat row and use jumper wires between each resistor and the driver IC and the resistor and the LED.
I know that that requires an additional 14 jumpers but that is better than blowing your LED.
gelzky
Joined Dec 7, 2021
86
yes thank you I notice that it still does not produce high output. I'll try to do what you're suggesting I'm just a bit confused on what exactly to do :3
ericgibbs
Joined Jan 29, 2010
21,568
Hi g,
Just follow what I said about the modification.
E
Once we have it working, I will explain.;)
When fault-finding in a circuit, if possible, ensure that the output stage is working correctly.
You can then use the output stage to help fault-finding the problem that is in the earlier stages of the circuit.
gelzky
Joined Dec 7, 2021
86
Hi g,
E
I already connected a resistor I only connected 1k ohm but still it does not produce high output:<
gelzky
Joined Dec 7, 2021
86
yes sir, noted. I'm still trying to figure out this circuit. thanks for your suggestion:>
ericgibbs
Joined Jan 29, 2010
21,568
hi,
Post the sensor description type/number, I will get the datasheet.
E
Note: don't mess with the untidy LED wiring at the moment.
ericgibbs
Joined Jan 29, 2010
21,568
hi g,
Well, all the information I can find states that the module has an internal pull resistor.
Does the onboard LED light when you move an object in front of the emitter/detector.?
Also, have you adjusted the sensitivity pot.?
E
BTW: if you did power up the unit as shown in the earlier photos' you may have damaged the module.?
I suggest you post an up-to-date photo of the project which shows how it is interconnected.:)
gelzky
Joined Dec 7, 2021
86
hi g,
E
thanksomuch for this. Yes the led onboard lights up. but I'm confused on what will I do. and I think my 7 segment display is broken :<<< it just gone crazy;<
