[Solved]Could you help me to understand the timer interrupt
35,124
But it is very important for me to know why you think that this problem can be solved by the state machine.
Read the title of your thread.
If you intend to use timer interrupts, how do you propose to use it?
35,124
A flowchart shows the flow of a process.
@hexreader has given you a simple solution in post #65 based on a simple flowchart along these concepts:
yellow off, red on -> delay for 1000ms -> red off, green on -> delay for 500ms -> green off, yellow on -> delay for 200ms ->
A state diagram and a flowchart are two different things.
A state diagram shows all possible states of an element and how to get to and from that state.
Djsarakar
Joined Jul 26, 2020
489
MrChips My question is still the same, how do you find out that the state diagram will be useful why I am not able to think so? Where am I making a mistake in understanding the usefulness of the state diagram
Did you see my state diagram which is in another thread post #50, does it looks correct?
What is the actual purpose of your given state diagram, what works it does?
Djsarakar
Joined Jul 26, 2020
489
Timer interrupts every 100ms.
When timer interrupts, increment a software counter.
Reset counter at 17.
Counter
5 Green OFF, Yellow ON
6
7 Yellow OFF, Red ON
8
9
10
11
12
13
14
15
16
17 = 0 Red OFF, Green ON
Does it makes any sense
35,124
No. You are attempting to draw a diagram based on what I wrote.
That is doing it backwards.
You draw the diagram first based on what YOU think ought to happen.
These are mistakes students make.
1) They add comments to their code after the code is written because their instructor says comments are required.
2) They draw a flowchart after the code is written otherwise they get low marks for the assignment.
Djsarakar
Joined Jul 26, 2020
489
Problems description
1. Red ON, wait 10000 counts, Red OFF
2. While Red ON, I want Green ON, wait 5000 counts, then Green OFF
3. While Red and Green ON, I want Yellow ON wait 1000 counts then Yellow OFF
4. Repeat process
Hope it describes correct
35,124
You are not thinking this through intelligently.
How are you going to detect when the timer register is equal to 60536, for example?
35,124
No. That will not work.
The timer is incrementing faster than your computer is processing.
You will never be able to catch the timer register at an exact value.
Could you help me understand the timer interrupt
As I already pointed out, you need to get the timer to trigger an interrupt at a defined interval, preferably at not too fast rate, milliseconds is ok.
In my solution, the timer triggers an interrupt once every 100ms. Done. That is all you need to know in order to work out a solution.
Djsarakar
Joined Jul 26, 2020
489
Ok so the response time of led is slow so we don't need timer interrupt
Is this diagram looks correct from the perspective of a state diagram?
trebla
Joined Jun 29, 2019
599
LED response time is critical if you are reading LEDs pulses with some optical sensors in high speed. Othewise only human eye response time matters there.
jpanhalt
Joined Jan 18, 2008
11,087
Still don't see why you have the 4th state. There is no such thing a "0" time.
If you want a 4th state, try Red on, yellow on, green off after Red on and everything else off. Years ago, some signals had that to anticipate green coming on. The obvious happened happened when the anticipators and yellow-light runners met.
It is now illegal in the US. I suspect that is why the pedestrian countdown signs are difficult to see from a car unless you are right at the crosswalk.
jpanhalt
Joined Jan 18, 2008
11,087
My comment about traffic lights was meant as an "aside." It's a problem with multiple, related, perpetual threads without any real question to be addressed.
Since you think there is "0" time. How will you code for that? Does a "state" with no existence have a purpose?
jpanhalt
Joined Jan 18, 2008
11,087
OK. Since you seem to be in lockdown and bored stiff, consider this problem:
You have three lights (R,G, and Y) and each is individually turned on or off by an interrupt/switch. There are 8 states:
a) All off (1 state)
b) One on and two off (3 states)
c) Two on and one off (3 states)
d) All on (1 state)
What is the fewest number of steps you can devise to get all 8 states if ONLY ONE light can be changed at a time? Show each step.
Djsarakar
Joined Jul 26, 2020
489
So LED takes time to turn on, off, you have not mention this delay time
Which sequence of RGB do you want when a switch is pressed or an interrupt occur?
35,124
What do you mean by LED has response time?
Define response time.
What do you mean by LED takes time to turn on?
What does this have to do with interrupts?
