Solid State Relay Design For 24VAC
DJ_AA
Joined Aug 6, 2021
502
Hi All
I am new to the forum.
I am working on a project, where i need to control 24VAC solenoids using my microcontroller. Previously i have used standard bulkier relays, but i now need some thing much smaller in design, therefore aim to use the AQH2213AX SSR.
Can anyone advice, if the design below is correct or do i need to have any additional components for any type of filtering?
My power source will from a 240-24VAC transformer.
Thank You
MaxHeadRoom
Joined Jul 18, 2013
30,860
It would appear that you could drive the SSR without the need for Q4.
If you think you need it, a 2N7000 would be a better choice.
Papabravo
Joined Feb 24, 2006
22,115
What state will transistor Q4 be in if GPIO_A is uninitialized, or high impedance, and unable to control the base of Q4. Do you want the relay to be default "ON", or defaut "OFF"?
I agree with Max. An external pullup resistor will default the relay to "OFF", and you can pull it low to turn it on. If you are determined to use a transistor then you can use a common gate/base arrangement to do it.
DJ_AA
Joined Aug 6, 2021
502
I will be adding a pulldown resistor. I must have missed it out
DJ_AA
Joined Aug 6, 2021
502
Q4 will be needed, as this design is likely to be powered with 5V and my Microcontroller from another board is working with 3.3V.
The reason for using a MMBT3904LT1G is because i have multiple reels of them which need to be used.
Papabravo
Joined Feb 24, 2006
22,115
Where will you be adding the pulldown? What will be the value with respect to the base resistor going to Q4?
