Solenoid
phuzionz
Joined Dec 5, 2008
47
Do somebody know more about solenoids?
I have a pressure regulator solenoid, and the manufacturar suggest to drive this with a lower PWM frequency. This can improve the hysteresis problem.
Have somebody from you already deal with that problem.
How can a lower PWM frequency solve that problem.
Jef
PRS
Joined Aug 24, 2008
989
I'm not familiar with your particular problem. But PWM is a means of varying the power available to the load. Instead of just raising or lowering a voltage -- the usual method of varying DC voltage, hence current and power -- you accomplish the same thing by sending DC voltage in spurts that last a certain amount of time as determined by the PWM circuit. The longer the spurt the more the power, the shorter spurt the less power. This varies the power applied to the solenoid.
I'm not sure what the hysteresis problem is, but this is how PWM works.
DrNick
Joined Dec 13, 2006
110
They are referring to hysteresis losses in the core of the solenoid. As the frequency of the excitation in any magnetic system increases, more eddy currents are induced in the core. Heating and loss come with eddy currents. Therefore, to avoid excessive heating and unnecessary losses, a lower frequency PWM is suggested.
One other advantage of PWM control of the solenoid is, you can drive high duty cycle when actuating the solenoid, and then reduce the duty cycle to provide the minimum current required to keep the switch/plunger at its desired position. This will allow you to consume less power under steady state operation.
phuzionz
Joined Dec 5, 2008
47
Thank you for the anwers.
@DrNick
I try to understand the relationship between the PWM frequency and the eddy currents induced in the plunger of the solenoid.
Can you help to understand it better?
Jef
bertus
Joined Apr 5, 2008
23,005
Perhaps this link in the wiki will say someting more :
http://en.wikipedia.org/wiki/Eddy_current
Strength of eddy currents
Some things usually increase the size and effects of eddy currents:
  • stronger magnetic fields
  • faster changing fields (due to faster relative speeds or otherwise)
  • thicker materials
  • lower resistivity materials (aluminium, copper, silver etc.)
Some things reduce the effects
  • weaker magnets
  • slower changing fields (slower relative speeds)
  • thinner materials
  • slotted materials so that currents cannot circulate
  • laminated materials so that currents cannot circulate
  • higher resistance materials (silicon rich iron etc.)
Greetings,
phuzionz
Joined Dec 5, 2008
47
So when you use a PWM frequency you get normally an average current, but the solenoid sees that really as an ON/OFF operation. Due to rapidly changing the flux, more eddy currents are induced.
So normally i use a frequency of 1Khz, but when i use 400Hz, does that mean that my OFF period is longer?
And i can also make my lower frrequncy with a longer and shorter ON period, but it stays 400Hz, can that also affect the eddy current?
Jef
Bernard
Joined Aug 7, 2008
5,784
If the ratoi of on to off stays constant average power should stay the same neglecting losses.Can you feel any difference in plunger temperature at different frequencies?
phuzionz
Joined Dec 5, 2008
47
Sorry, I am not be able to test that because i'am now in a syage to select a solenoid according some requirements.
One of these is a lower PWM frequency.
Jef
phuzionz
Joined Dec 5, 2008
47
I'am struggling a quite long time with this, without any result.
Can somebody tell me the relation between eddy currents and PWM frequnecy.
I know what eddy currents are, it is already posted in this topic, but the explenation behind it, i can't find it.
With faster magnetic fields, you get more losses due to the eddy currents. This statement isn't clear for me.
Thank you,
Jef
