MisterBill2
- Joined Jan 23, 2018
- 27,647
While the revered connected diode will do a very good job of reducing the arc it will also very much slow the collapse of the magnetic field. The result may be a change in the performance of the motor. And one more thing, the 1N4004 is still only a 1 amp diode! They vary in allowable reverse voltage spec from 50 volts for the 1N4000 to 600 volts for the 1N4006, or maybe the 1N4007. At any rate, it is a family of 1 amp diodes.
Another option, instead of diodes, would be light bulbs. 24 volt pilot light bulbs would probably both reduce the arcing and put on a good show.
