I had a Sole F63 that would power up OK, but when you try to start it would make a whining noise then throw error code E7.
Previously I had followed the repair guide by mike_haben which did fix the issue the first time.
Upon further investigation, I found that the main 12VDC relay was not actuating properly. (replacement part number: J115F11A12VDCS6.9)
Removing the coil then testing it found no issue with the relay.
Examining the board with thermal camera showed Q100 was heating up when the motor would try to turn on before faulting.
I replaced the NPN transistor on Q100 with MMBT2484LT3G from onsemi and the treadmill has been working properly every since.
A couple of week later, same issue, but the culprit was not one of the power MOSFETs.Fault was that one of the two IRFP460A power MOSFETs on the motor control board had blown
This fix may also be applicable to Flow Fitness DTM2000 and DTM3500 treadmills, which use a variant of the same motor-control board.
