Sole F63 Treadmill not powering on
Zhandoo
Joined Sep 8, 2024
I’ve a very similar issue to the one discussed a while back in the following thread
https://forum.allaboutcircuits.com/threads/need-help-troubleshooting-sole-f63-2016-model.168390/
My treadmill is also from around 2016. Main power comes on but treadmill console is dead. Likely an issue with circuit breaker or the board. Trying to figure out what is it. I can see a faint green light come on for power on the board but that’s it. Not sure if a part of the board is blown or circuit breaker has issues (doubt as board has some power). The Google album with photo of the board and a video showing light coming on is here:
https://photos.app.goo.gl/mhxJuLdE2c6g5aqz8
Thank you for your help.
MaxHeadRoom
Joined Jul 18, 2013
30,776
Generally the A.C. power goes to the main board where the low voltage is generated, it then send it up to the console.
See If there are any DC voltages 10vdc to 20vdc on the console itself, also test the source on the main board.
Zhandoo
Joined Sep 8, 2024
Thank you for the quick reply. Will it be possible for you to tel me where on circuit board I check for the power, DC and AC? I can see power20 light flickering dimly (see small video in the link).
MaxHeadRoom
Joined Jul 18, 2013
30,776
Unfortunately I am not familiar with that model. mostly the MC2100 versions is my specialty.
You would need to do a little reverse-engineering of the board.
