Soldering on stainless steel
Vindhyachal Takniki
Joined Nov 3, 2014
598
I have small strips of stainless steel 202 grade (5cmx2cm) , thcinkess is 0.4mm of sheet.
I tried to do direct tinning of it on small area so that i can direct solder wire on it for use. Tempearture of iron is 425C.
Sometimes tinning happens and sometimes not? whats the right way to do it?
Ian0
Joined Aug 7, 2020
13,272
Sometimes you're better off with lead-free solder. As solder it's not as good as tin-lead normally, but that means it has to have a more active flux, and that often helps with soldering difficult things like stainless steel.
What you really need is a TIG welder.
shortbus
Joined Sep 30, 2009
10,049
There is flux specifically made for stainless steel.
There are more than that one. The best I ever found was Eutectic 157. Did a lot of soft soldering of different stainless steels back in the day, and the company tried many different fluxes and this was the best we found.
https://www.castolin.com/en-US/product/eutector-157-0
I hope you aren't thinking that 202 won't rust? Many people think when they see the words, "stainless steel" that all of them are rust free, not so. https://www.machinemfg.com/stainless-steel/
