Soldering & jumper wires
dl324
Joined Mar 30, 2015
18,337
It seems very very tiny, already having problems with my current wire.
How much current do you want the wire to carry and how long is the wire?
But maybe it's easier when it's not stranded?
Stranded wire is used when flexibility is required. If you're using it for point to point wiring on a PCB, flexibility isn't normally a factor.
outro
Joined Mar 7, 2017
43
Exactly, flexibility is more of a problem in this case
I think about voltage/current, maybe max MAX 5A? @12v
dl324
Joined Mar 30, 2015
18,337
I'm having difficulty envisioning a situation where wire flexibility of #24 or #30 would be a proble
I think about voltage/current, maybe max MAX 5A? @12v[/QUOTE]#24 can carry 3.5A, 0.86A for #30. Voltage rating depends on insulation and conductor separation.
