recklessrog
- Joined May 23, 2013
- 985
#12 is absolutely correct, and he has given the reason for "crackling" leads, and I have heard speculation that with certain insulation types, the movement of the shield over the insulation can cause minute amounts of static to build up causing "crackling" noises, but these seem to be cheap poorly made leads.
I have been a guitarist for over 50 years, owned 36 les pauls, 3 telecasters, and a host of other guitars, designed, built and repaired countless amplifiers, owned and run a 30kW P.A, been the "go to guy" to fix problems, and the only solid wire I have seen in a guitar is a piece of 18swg used to earth the potentiometer mounting plate to the bridge.
Under NO circumstances would I contemplate or advise using solid wire inside a guitar, as sooner or later it is bound to fracture.
