Solar Simulator White LEDs flickering
Status
Not open for further replies.
alatza
Joined Aug 16, 2019
Hello everyone,
I'm making a solar simulator with 13 white LEDs in series, they operate in 20V/450mA in full brightness (YUJI VTC Series LEDs 135L).
As a power supply I'm connecting 220V mains to a Variac, then to a full bridge rectifier and to 2x 400V/680uF capacitors in parallel.
Even with so much capacitance, when I increase the voltage on the variac, the LEDs start to shine around 210V, but when I reach 238V, about 70mA, the LEDs start to flicker and I can't reach maximum brightness.
I saw the ripple on the scope and is about 600mV peak-peak.
What am I doing wrong?
Thanks for any help.
Best,
Marcelo.
DickCappels
Joined Aug 21, 2008
10,662
From the forum's User Agreement:
  1. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Any kind of jammers (ie - Phone jammers)
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
In other words, we are not permitted to discuss this kind of circuit, though you should be able to find other forums that allow discussion of this king of circuit.
Status
